electechbw
We are trying to use a 5000 watt generator to run a ULT cascade freezer in the event of a power outage utilizing an extension cord. The generator has two 5-20 duplex receptacles, rated at 2500 watts each, and one L14-30 receptacle rated at 5000 watts. The freezer runs at 120V/16A according to the data plate. Is it possible to hook the hot lines from the L14-30 outlet in parallel, so that we can utilize all 5000 Watts on one 120V circuit?
[automerge]1574450661[/automerge]
Looks like I'll need a transformer instead.
