Hey all, so I'm rewiring a nightmare house while girl still living in it ! Plumber gets a cylinder and says direct 1 X 3kW standard immersion. So I run a 2.5 through most of house to loft.. Comes today saying just worked out he got wrong cylinder and where he wants it there is no space for vert so he gets a horizontal one which has 2 X 3kW elements instead ! I was going to leave dp switch and a grasslin timeswitch at source in garage to control it but as now 2 elements would you... Run a second 2.5 from seperate rcbo and second dp or I'm thinking maybe add a 4 pole contactor and switch coil of it with the time switch to bang on both elements in unison ? Trying to be cost effective and sensible or run a 4/6mm twin and split from a cooker outlet or similar at cylinder on 2 x 2.5 flexes to elements ?
