Horstmann Thermostat | on ElectriciansForums
Discuss Horstmann Thermostat in the Central Heating Systems area at ElectriciansForums.net
London
[ElectriciansForums.net] Horstmann Thermostat
Hello all,
I just moved in to a new flat and it came with this beauty. I have absolutely no idea how to operate it, though and there’s no manual anywhere to be found.
The boiler is placed behind a bed so it’s not easy to access on a daily basis.
I think I can programme it if I spend enough time on it, but what I want to know is if it’s possible not to programme it and just use it as you go, daily.
Also, can you turn the heating off with it?
help ?
Reply to Horstmann Thermostat in the Central Heating Systems area at ElectriciansForums.net
I have just looked at the wiring diagram on line and there are a lot of internal links which if in the wrong terminal could put 230 volt onto...
glad it was such a simple fix..... And good job the previous owners didnt take it with them
