hot shower swtch | on ElectriciansForums
Discuss hot shower swtch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
steve.l
Hi , the switch to my shower gets very hot after the shower has been running for around 3 minutes .The shower was fitted about a year ago and has been fine up to now, the wires in the swutc are all in place and tight.. thanks
thanks for the very quick response , im not sure of the rating sorry ,im not at the house right now to check, i had a electrician do the wiring.
If the switch is getting hot then there is a problem. Get the sparky who wired it back to check it out, chances are it will get worse over time, not better.
Hi, get the switch replaced with a crabtree 50a switch, they are very highly recommended and have lots of wiring space .
Kind regards,
Decolad69
Ok thanks for all your help, i will get more info on the matter and get back to you. The shower is not being used at all . It is my daughter in-laws house thats why i dont know much.... thanks again
if it's to the south or west side of manchester, i can sort it for the sake of a call-out fee + any materials needed.
I have the same problem in one of my en-suites. 8.5kW, 6.0mm2, C32A, no insulation, DP switch, tight connections, hot totty when I touch it - crap switch !
I'll upgrade it when I can find a decent spark, - lol
Reply to hot shower swtch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
H
need a new shower but my hot/cold pipes are reversed! Hi All I need some advice as to a replacement power shower and there are a few problems I...
harrygee
H
Being pedantic, the Crabtree 50A cooker switch is a 4500/1, which has 'cooker' printed on it. For a shower, you require the 4500, which is the...
