Boomerrat
Hi, just finished fitting my hot tub and need to run a 45m length or armoured cable from the garage to it. Next to the tub will be a summerhouse with a couple of sockets in it nothing heavy just a phone charger and stereo. The wiring it used to have when I bought the tub was 16mm outer / 4mm inner but I have been told 4-6mm will suffice as the tub states on top it is 16amp /230v, inside on the wiring diagram it shows a jumper setting of 20a-50a? Really confused as to whether the 16mm cable was purely overkill and 6mm will be fine and the other information on the wiring diagram?? Any help will be greatly appreciated.
