dean7828
hi chaps, i have recently installed a hot tub which consists of a supply from main db running to an ip rated dist board which is located out side which contains an RCD and an mcb through a rotary swich supplying the hot tub, they are now asking me to fit a timer to the circuit so the the hot tub is not running all the time, i would like to get one that i can fit in the outside DB but cant seem to find one, can anyone point me in the right direction? as allays money is an issue so need the most affordable circuit possible.
thanks in advance
thanks in advance
