Pat H
Hot tub in a garden next to a wooden summer house.
I need to add an isolator.
Ideally it would go on the side of the summer house as the CU is just inside but that puts it closer than 2M of hot tub (isolator is IP65)
The next option is inside the summer house but I'm less keen on that as the summer house could be locked up so the isolator inaccessible.
I'm thinking I could install the isolator inside the under tub equipment space which is closed off with a door. AM I correct that like a bathroom as long as its inaccessible its ok to be within the 2M?
