M
MJBritton25
Hi,
Ive been asked to cable a hot tub, and its my first time, so any help would be appreciated!
Running some steel armoured 25 metres from the consumer unit into a drybox. The drybox will have small consumer unit with a 40A supply and be connected to a 32AMP hot tub, and will also run a hifi and a couple of sets of LED garden lights - they will be connect to ip66 sockets.
I'll use the same armoured to go from the small consumer unit to the hot tub
What size armoured should I use - was thinking 6.0mm three core should be more than sufficient?
Also, i understand the drybox needs to be 2metres at least from hot tub - I assume the same applies to any ip66 switches or sockets ?
