M
massifal1
Hi People,
First of all let me state I am not a spark , I wont be doing the final connections on this .Just doing a first fit ,mounting switches running cable etc then getting someone to connect tails etc.
So let me begin with what I know
I am Installing a hot tub which has a total power consumption of 8.5 KW (but all things will not run at one time )
specs say i need 32a isolator and mcb 32a & rcd 32A 30Ma/40Ms
Tub is inside house on solid concrete floor. Tub has 3M tail of armoured cable attached.
I need to mount ip65 rotary isolator >2m from tub
Distance from isolator switch to board < 10m
running back to board in 6mm grey (inside of adjoing garage wall )
two main questions really
At board I have a seperate 2 way consumer unit which is a Wylex NHRS204/63GWU which runs shower (9.5kw) on a nsb 40mcb
Can I use other spare outlet and change the 63A rcd to say an 80A ???? with a 32A rcd ??
thats the easy bit for you really !!!!
Now the controversy
The earthing in the house is PME soooooo I have been looking around and getting different answers ,Does it need an earth rod ?????
Now the controversy
