P
Pigswill
Hi, i'm just after a bit of advice, i'm thinking of having a hot tub installed in the garden and i'm just planning on what i will need installing to power it up. I have some knowledge of electrics but i will be having all the important stuff done by a proffesional as i think what i need doing will be notifiable. I'll just get some of the donkey work done to speed things up and reduse costs.
To have the hot tub installed i will need a 32amp supply installed, as the garage is only supplied with 2.5mm armoured i know this wont be sufficient to handle the hot tub.
I live in a new build house, and the problem is there are spaces left in the board in house. Is it possible to add another sub board from the main board like the the rcd protected units you get for showers but swap the 60amp for 32amp.
I'm just accessing what can and cant be done. If it beens i've got to get a bigger board installed then the idea is dead in the water.
What are my options ?
Thanks in advance for any advice.
