Hot Tub | on ElectriciansForums
Discuss Hot Tub in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
haj
East Yorkshire
Hi Guys
No details as yet but i am thinking that a hot tub needs to be on own supply direct from the main CU would this be correct ?
Hi.
Got to be careful with hot tubs mate....particularly when it comes to earthing the blighters. Nearly always you'll need to spike them, and be careful if you have a TN-C-S system, follow whatever the maufacturer says to the letter.
Reply to Hot Tub in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Anyone plumb a DIY hot tub? I bought a used acrylic hot tub shell that I plan to sink into the ground in the backyard. The plan is to heat it with...
siricosm
Thanks for that guys I was more thinking about difference in potential between the tub and wet paving flags . The tub is plastic . But it’s the...
