Hot water Contactor issue | on ElectriciansForums
Discuss Hot water Contactor issue in the UK Electrical Forum area at ElectriciansForums.net
South Wales
Evening all.
I admit I am not affay with the workings of contactors however, I have come across a domestic property that heating and water powered via economy 7 electric.
Recently, the water is running luke warm to cold. I have tested the circuit within the property to ensure there is a circuit throughout (from the CB to immersion). Additionally, I have changed the entry points to the contactor for the heating and water as the heating is still working.
Apart from having an early breakfast with the occupier, is there anything else I can do to test the workings of this.
PS the plumber has changed the immersion as an option but still no joy
If the water is Luke warm then there is power getting to the immersion..I very much doubt it's to do with the contactor. I would assume it's something to do with the thermostat on the immersion or the controller isn't functioning/timed correctly. I would get an electrician in to take a look.
Evening all.
What do you mean "changed the entry points"
Where the feeds to the off peak heating and water enter the contractor, I swapped the, to ensure both sides of the contractor were allowing power through. This made no difference as the heating was still working after being swappped.
Reply to Hot water Contactor issue in the UK Electrical Forum area at ElectriciansForums.net
L
Hot water issue with combi boiler I have a combi boiler, the hot water to my bath and taps upstairs is hot and stays hot, aswell as the hot tap in...
Lotte29
L
There is no reason for an item of fixed equipment to be on its own dedicated circuit just because it is fixed equipment. There may be other...
loz2754
L
