Hotpoint HMB313I fridge clicking on and off continuously | on ElectriciansForums
Discuss Hotpoint HMB313I fridge clicking on and off continuously in the Electrical Appliances Forum area at ElectriciansForums.net
tadast
UK
Woke up to my fridge clicking on and off every few seconds. It seems like it’s trying to start but then a relay/switch trips and it turns off. The lights inside and the LED display go off as well when it “clicks”. Here’s a video
Is this a common fault that’s easy to fix by replacing a part or do I need to get a specialist to look into it?
Thanks in advance
TL;DR
Fridge stuck in a restart loop
A few months have passed, did you manage to deal with this problem? If so, please share the solution for those who come across a similar situation. I decided to read the instructions for this model and found several possible reasons:
1. Motor protection control is triggered
2. Problem with the motor protection relay (should turn on 8 minutes after connecting)
3. Unreliable connection of the power cable
4. Incorrectly set positions of the refrigerator and freezer knobs.
Reply to Hotpoint HMB313I fridge clicking on and off continuously in the Electrical Appliances Forum area at ElectriciansForums.net
Try disconnecting the "central heating off" wire from terminal 2 and insulate it (eg Wago connector or choc block or similar) and tuck it out of...
2 3
4K
