House alarm and doorbell from 6amp MCB? | on ElectriciansForums
Discuss House alarm and doorbell from 6amp MCB? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
loughborough
Hi
Just preping to have a home alarm and doorbell transformer wired to my cu
Both require a 6amp MCB, can I wire them both from the same MCB?
If I keep them seperase I won't have any spare slots as I need to put in a 2 slot transformer
I won't be doing the wiring, just need to get materials
I think the alarm should be on it’s own curcuit.
Bung the doorbell in with the lights. You could use a standalone transformer, not one that fits in the db.
If a full alarm system, the maintenance & monitoring contract may require the system be on a dedicated circuit. Check with the service provider (or manufacturer's guidelines, if it is just a local alarm without maintenance/monitoring)
Hi
Leave it to the Leccy to sort out materials Sunil.
Reply to House alarm and doorbell from 6amp MCB? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
These keypads are obsolete and replacements are hard to find, I've replaced loads now with failing displays. Sounds like something isn't...
M
I meant EIC, No idea why I put EICR down, thanks for the clarification
