B
bk1
Recently I moved in into a new-built house. When installing the lights (chandeliers, etc.) I noticed that on some lights there is voltage in the cable, even if the light switch is turned off. Later I discovered that this problem happens only in the lights with two or more switches. Because I measured up to 120V AC in the cable (between L and zero wire) when the switches were off, I called the my electrician who said that this is due to induced voltage. We actualy proffed this when we temporary changed the wall cable with a cable that ran inside the room and there was under 3 V of induction (because the wires were far apart). Electrician said that this is not a problem, but I am still concerned because 110V when lights are off is quite a lot in my opinion. What do you guys think?
