Not sure the way those smoke detectors are connected is exactly snagging.
Those smoke detectors generally are a poor design, but should fixed into a fast to fix box as previously said with some wagos jointing the cables. Could have atleast put some tape around em
Edit: Also he has not identified the 3 core black and grey as line or neautral
I've always fitted the aicos so have brought the cables into the term blocks but I like that idea of the circular fast fix, you and @Flanders mentioned. Would be an easy fit with the number of refitting holes they put in the bases.
Are the Aicos the ones where it's still tight to get all conductors in the space and the slide the head on?
Yeh but with just the power then link it's not a bother - you do measure the conductors though and the lid is a hinged affair which helps.
Ahh not the ones I've fitted in the past then which have been a right pain in the arse (think in a blue box?) been a few years. A fast to fix with a couple of stuffing glands in can't be beaten, a few extra minutes for less hassle and a top notch job (unless ins latt&plaster then It's a c**t.)
I use some form of back box with Aico, nightmare to terminate properly otherwise. They've allegedly changed the design, to making the connections more easier!
Why do you need a back box? Bring the cable(s) through the ceiling, connect to visible connectors...... If the cable is a bit long, push a bit back into ceiling void. Simples
Well, the distance between terminals and base plate is minute, so stripped back cables are exposed behind fitting, however careful you try to be. Back box for me.
I don't think it was cheap - £3500.
Can i also ask about the mains wires touching the central heating pipes - is this ok or should they be clipped away from the pipes or can the pipes have insulation around them? If it is a problem is this something the electrician or central heating installers should do? Many thanks
If the electrician is second in the space he should fix them out of harms way away from the pipes. If the plumbers second in the space he should make sure his pipes don't touch,however he/she is a plumber so not something to rely on. In each case once fitted its not often that either go back to that area so it depends really on the last one fixing something but it is a joint responsibility to keep cable away from hot pipes.
Manchester
House Rewiring Compliance
Thread Tags
Jo.Forum,
westward10,
