Hi all, not a housebasher here, so don’t hate. Wiring my house and need advice. Want to mount the CCU just below the ceiling and bring the cables from the floor above. How do a nicely bring the cable off of the beam so they’re on the wall and then will go into the back of the fuse board? Pics attached
In rural Europe thee phase in Domestic properties is not unusual and they call the container box by every conceivable variation, even in the regulations they confuse the issue, but for all intents and purposes does it matter, we all know what we mean. 😇
Distribution board (DB) is a generic term for all of these. A consumer unit is a particular type of DB intended for use by ordinary persons (DBO), which is type tested and single phase with a double pole main switch. As such it is not incorrect to refer to a CU as a DB, although not all DBs are CUs.
EDIT: Much as @pc1966 has stated.
I think this intriguing study explains it all.
I think most folks still think "fuse box" even though fuses have not been the norm for many years now.
I believe a CU is defined as a DB that meets specific type approval for domestic use, so DB is a more generic term.
I posted similar thoughts in another thread, some time back.
Regardless of everything, 'consumer unit' has no meaning to anyone outside the trade and is a daft term.
While incorrect, 'fusebox' has meaning for domestic customers and its use in conversation is understood by all involved. DB covers all types of distribution board and is understood by everyone in the trade.
I gather that CCU/CU was introduced as a term for domestic DBs, to replace incorrect use of 'fusebox', but it's a nonsense term and I refuse to use it unless absolutely necessary. I won't encourage the madness of others 😁
K
What is the room where your going to locate CU/CCU/DB/FuseBox? Could you run circuits/tails in plastic trunking?
You do need to think about Notification, which Country do you live in?
hmm ideally not. It’s in the hall in plain sight. Not tucked away anywhere nice.
I live in England. I’ll probs get a part p spark round before I run anything and then get them to cert it
I have to agree with this. 'consumer unit' is as vague as it gets, and 9 out of 10 customers don't have a clue what it is.
Although I use the terms Fusebox and consumer unit. The majority of the time I call it a board.
IE.. Where’s your board located? What RCBO’s will fit this board, look at the state of that board, who the F… still installs split load boards these days? Etc…
Legrand and many others offer these purpose made duct's to take a DB, CU or whatever you want to call, they are floor to ceiling units and tidy up what could be a messy area: https://www.leroymerlin.fr/produits...l-legrand-h-260-x-l-25-x-p-6-cm-70564011.html
They also offer a splayed head unit to accomadate multi choise entry.
Really like the look of those ducts/spreaders. Can't imagine they're cheap and the linked site won't let me in, but I've never seen anything like this in a domestic situation. In fact I've never seen anything like it in PVC.
Chester
United Kingdom
Trainee Electrician
Housebashing wiring helped
UK
Shpark,
default,
