How accurate are cheap CT meters | on ElectriciansForums
Discuss How accurate are cheap CT meters in the Electrical Tools and Products area at ElectriciansForums.net
London
A client of mine wishes to verify the accuracy of some meters, I was thinking something like the below could be fitted to a 13a plug and moved around more easily than a conventional meter, would you expect reasonably accurate performance from something like this?
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
I wouldn't be confident about the accuracy of that. Might be OK but how do you know?
Firstly I suspect you would be better off with a split-core current transformer, so you can clip it on the cable of an existing installation, and secondly I would suggest buying something built to a standard - eg meter accuracy standard "MID".
I'm not necessarily recommending the thing below, but it's illustrative of the sort of kit built to a standard and it would be accurate.
(You would need to be able to plug it into the mains, unlike the battery powered instrument you show, but I guess that shouldn't be too big a problem)
normally to check the accuracy of a meter you would use a load bank.
they are available to hire.
they should come with a calibration certificate to show they are accurate.
That's probably a better option thanks
I intented split core anyway, the idea is to leave him something he can move around himself subject to there being a socket
Reply to How accurate are cheap CT meters in the Electrical Tools and Products area at ElectriciansForums.net
https://www.amazon.co.uk/Fike-Rafiki-Twinflex-09-0026-Panel/dp/B01BKQCR7Q/ref=rvi_d_sccl_6/259-6940442-6992409?pd_rd_w=1mkG1&content-id=amzn1.sym.d...
