C
currie123
Hi
I am going to be running a power supply to a small garden shed on a large caravan site, the shed is owned by the owner of the static caravan to which the shed is beside. Closest power supply is the pitch box, I am running a 6mm swa cable from here to shed( in my Mind pretty straightforward run of 8meters or so).
From memory the pitch supply box has 2 4core16mm cables, two 3 p and n loops from other pitch boxes presumably and the armours are bonded together in the pitch box.
The static caravan is a tt system with an earth rod underneath it which I fully understand. My question is how should I earth the small shed? By way Iof separate rod for the shed or can I do a Ze test at pitch box and if a good reading can u earth by way of the earth of the swa's in pitch box? Unsure of earthing arrangement at the supply distribution board as I have not seen it.
Point to further add it is impractical to run supply from the caravan itself as cable run too far and troublesome, thanks
