How buzzer work transistor | on ElectriciansForums
Discuss How buzzer work transistor in the UK Electrical Forum area at ElectriciansForums.net
I'm sure someone will correct me if I'm wrong, but in the majority of use cases transistors are used as amplifiers. In this case it could be it's being used as a switch, allowing a small current (the output from say a microcontroller) to switch a larger current (the current required to drive the buzzer).
But it could also be being used to create the signal that actually makes the sound. You can create a simple square wave oscillator using a very simple flip-flop circuit.
So, with the limited information you've provided, I'd say it's being used as a current amplifier to switch the power to the buzzer.
I suspect you're wasting your time SC.
Reply to How buzzer work transistor in the UK Electrical Forum area at ElectriciansForums.net
Hey all, I am trying to set up a module that i can use to turn on headlights with lock and unlock so basically I have all things sorted out...
It applies to commercial if it shares the same supply as a dwelling.
