How can I safely use a German coffee machine in the UK? | Page 3 | on ElectriciansForums
Discuss How can I safely use a German coffee machine in the UK? in the UK Electrical Forum area at ElectriciansForums.net
Mexico14
Wirral
Could any help with my query please? I bought a coffee machine but it come with a German plug, can this be used safely in the UK? It works with the adapter pictured. However shouldn't a coffee machine be earthed? Any advice is appreciated.
[ElectriciansForums.net] How can I safely use a German coffee machine in the UK?
Only if carried out by a qualified electrician. Anyone? :)
No. By anyone competent to fit a plug. It is well within competent DIY or handyman scope. If it is done correctly there will be no issue.
How does anyone know who fitted the plug anyway?
To the OP - get someone competent to fit the plug, or do it yourself if you feel you are able to safely. If anyone from Bosch ever says 'who fitted that plug?', the correct answer is 'a qualified electrician sir'.
I really hope common sense has prevailed here already though!!
Just playing Devils advocate, if you have a read of my other thread. If there's a warranty claim, you may be required to prove whose replaced the European plug, not just 'Dave' from down the pub.
Feel sorry for these 'Daves'.
Even if you had an electrician fit the plug, most I dare say, would not issue a certificate to say they had fitted the plug. So difficult to prove anyway.
Reply to How can I safely use a German coffee machine in the UK? in the UK Electrical Forum area at ElectriciansForums.net
This UK company seem to sell parts for them so it might be worth contacting them after that you could try the manufacturers La Rocca | Máquinas de...
Yeah, the safety and aesthetics would need to be assessed by the person installing it and my suggestion may not be a practical solution depending...
