how can i take breaker ics rating? | on ElectriciansForums
Discuss how can i take breaker ics rating? in the Australia area at ElectriciansForums.net
M
mateen
hi i wanna know that what is the abbreviation of ics and icu? and how can i take my ics rating of the breaker? is there any formula or calcualtion? and i wanna know short circuit rating ics of single pole and tripple breaker ? how can i take it?
[SIZE=+1]Ultimate or rated short-circuit breaking capacity(Icn - EN 60898)A breaking capacity for which the prescribed conditions,according to a specified test sequence donot include the capability of the MCB (Miniature Circuit Breakers) to carry 0.96 times its rated current for the conventional time.Ultimate short-circuit breaking capacity(Icu - EN 60947-2)A breaking capacity for which the prescribed conditions,according to a specified test sequence donot include the capability of the MCB to carry itsrated current for the conventional time.Service short-circuit breaking capacity(Ics - EN 60898)A breaking capacity for which the prescribedconditions according to a specified test sequenceinclude the capability of the MCB to carry 0.96times its rated current for the conventional time.Service short-circuit breaking capacity(Ics - EN 60947-2)A breaking capacity for which the prescribedconditions according to a specified test sequenceinclude the capability of the MCB to carry its ratedcurrent for the conventional time.[/SIZE]
On the front of BS EN 60898 MCBs and 61009 RCBOs you will usually find two sets of figures, one set enclosed in square box and the other in a rectangular box.
The square box, the Ics rating (kA), is the maximum current the device can interrupt and still be serviceable. A fault current above Ics would render the device unserviceable and would need to be replaced.
The rectangular box, the Icn rating (A), the maximum current the device can interrupt safely. A fault current above the Icn rating would be very dangerous and possibly result in an explosion causing major damage to the DB
Reply to how can i take breaker ics rating? in the Australia area at ElectriciansForums.net
Hi There How did you get on with your basement project?
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
