Hi, I have a customer who has bought a 16A charger which will obviously only charge at 13a from a UK socket. Their question is would the be able to use the full 16Amps if they have a 32Amp breaker? Thanks
Discuss How can I use a 16A charger on a UK socket? in the UK Electrical Forum area at ElectriciansForums.net
Hi, thanks for your message. It is a variable charger that can operate between 6A and 16A so it is defaulting to 13A and charging fine.Unfortunately, it WILL NOT obviously only charge at 13Amps if plugged into a 13A socket.
Read the instructions, I expect it will require a dedicated 16A socket.
Also, take note of any requirements for rcd type and possible ground rod.
Yes it isIs this an electric car charger?
Hi, it is an electric vehicle charger which you can manually change and set between 6A and 16A. The maximum charge it will allow is 13A from a UK socket. The question I have been asked is is there anyway it can reach 16A from a UK socket using and adaptor?Unless it's got a built in camera with optical detection of socket types, there's no way the charger can detect it's plugged into a 13amp socket and or detect it's a circuit with a 16, 20 or 32amp MCB /RCBO protecting it and default to 13amp charging.
It's going to 13amp charging for other reasons.
In what capacity is this person your customer, do you own a shop and you've sold them the charger, are you electrically competent and you've been called to their property?
What make / model is this charger?
Thanks JamesIf it came with a 13A plug attached then it will be limited to 13A
If it is a charger designed for hard wiring then it is possible that there is a selection switch inside to change maximum current draw.
Read the instructions, I expect all the answers are in there.
Hi, if it has variable settings that can be set to 13A would it still damage the socket?Does this come with a standard BS1363 3 pin plug attached? Running at 13 amps will cause damage to the socket outlet over time.
With a charger such as this there may very well be current passed through the earth conductor meaning other requirements have to be considered for high earth leakage. What do the manufacturers instructions say?
afaik, ev chargers must be on a dedicated circuit of their own, there are other factors also regarding earthing. (unless, of course, it's little johhny's remote control F1/SUV/BIGFOOT.)
It depends on the type of charger, some can plug in to any outlet without a problem.
Constantly drawing 13 amps will eventually cause damage to the socket, how long depends on the manufacturer and quality of the socket and plug.Hi, if it has variable settings that can be set to 13A would it still damage the socket?
Reply to How can I use a 16A charger on a UK socket? in the UK Electrical Forum area at ElectriciansForums.net
