H
Hickmanb1
Hi, just wondered if anyone knew how deep you can channel into a wall? Does this come under electrical regs, or building regs?
Discuss How deep can you channel into walls? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Cheers for the info, probably only need to go about 30-35mm so should be fine in most walls.
Which in reality, would be hard to reach installing a few cables.
If you go by the regs saying that cable have to be 50mm or more deep if they are not RCD protected and a brick is approx 100mm deep that would be a bit more than 1/6 to 1/3 that Amp Dave said..
Reply to How deep can you channel into walls? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
