I have an elderly client that wants some additional sockets adding to a ring final circuit, some are simple spurs and some will need the ring extending - pretty simple jobs.
she also wants some independent switching in her lounge, an additional light in the hallway with 2 way switching - again, pretty simple job.
The issue/question I have is that there are is no RCD protection whatsoever at the fuseboard. I have mentioned this but as a recommendation but she can’t afford to get the fuseboard changed yet.
so when it comes to testing, how do I certify with no RCD tests? Is this simply a limitation and noted in the comments or am I not permitted to carry out the work without there being an RCD? I know the regs say that RCD protection is required and it also says that can’t do any work that will worsen the state of an existing installatio, which it won’t.
so is it acceptable to do the work such that the finished product will leave the installation in no less a condition than the existing one? Probably a simple answer out there but would like some views please.
The existing installation is a Wylex board with MCBs about 25-30 years old. Oh, and the original installers wired all the earths on the ring final together at each socket and all the cable in the loft is laying loose across the rafters with no clipping at all!! (This actually makes it easier to move/ replace!)
