Hi all,
I've installed a NEST onto a Eco Elite 30 combi that has a Salus rxbc605 (I think) unit installed - I removed the link between bk1 and bk2 near the main power terminals and wired the NEST switch wires into here - the NEST works but only when the Salus is on, but when the Salus tx shows off due to temperature or timer the NEST does not work.
Is is just a matter of opening up the main board cover and unplugging the cable that connects the salus from the pcb? My plan is to follow the cable from the rx unit to where it connects to the pcb (X9 connector)
Will this work?
Thanks in advance for any help
Will this work?
