How Do I Do This Once??? | on ElectriciansForums
Discuss How Do I Do This Once??? in the Australia area at ElectriciansForums.net
C
chrisgc
Hi all,
My brother has asked me to install the following at his work place yard:
INSIDE of SHED at the bottom of yard:
Install 1x Twin socket (these sockets will mainly be used to plug an extension reel into)
Install 2x Fluorescent lights
OUTSIDE OF YARD ATTATCHED TO TIN ROOF:
Install 2x Spotlights
Replace 4x damaged Fluo lights
At the moment he does have a CU inside his yard office BUT as of yet no CU in shed.
Should I just run everything off existing CU or would it be a case of Installing a new CU in shed etc.
I have just passed course so he is kindly giving me the oppurtunity to price up and install as my first job - so just making sure I am not taking on to much that I can handle.
If someone could give me a bit of a walkthrough list of what would be the best way to tackle this then I would be very grateful.
I look forward to hearing from any of you good people.
Chris
Reply to How Do I Do This Once??? in the Australia area at ElectriciansForums.net
With what looks like only 5 circuits you can probably put a little 5 way garage consumer unit in there if money is tight
