How do I get rid of phantom voltage on LED lights feed. | on ElectriciansForums
Guest viewing is limited
Discuss How do I get rid of phantom voltage on LED lights feed. in the DIY Electrical Advice area at ElectriciansForums.net
cammac
Scotland
Have switched a light fitting from incandescent to LEDS. The LEDs continue to glow slightly after switching them off. The fitting is switched 240V live wires and there is a AC 5.1V induced phantom voltage. Little or no AC current. How do I get rid of the phantom voltage. A 4uF 400VAC cap across the wires does nothing.
Similar queries here previously, eg: Advice (please) regarding suppressor / "snubber" for LED lighting | on ElectriciansForums - https://www.electriciansforums.net/threads/advice-please-regarding-suppressor-snubber-for-led-lighting.196363/
Normally a 'snubber' of C and R in series., eg 0.1uF and 120 ohm in one component.
4uF is a bit hefty for this job, and you really need an X rated capacitor (fails o/c) if it's across the mains!
Presumably the capacitor is actually across an LED light fitting?
You might try snubbers across every light fitting.
And is the switch a standard mechanical non-smart non-dimmer type, otherwise that could be the culprit!
Reply to How do I get rid of phantom voltage on LED lights feed. in the DIY Electrical Advice area at ElectriciansForums.net
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
I'd start by doing the usual supply impedance tests followed by N-E voltage with the installation under some load. Also visually inspect and...
Recommended Sponsor News
Hi everyone,
