M
Marie-Claire
Righties, im getting some down lighters, which connect to a transformer and has a plug. How do i connect them so they run off a light switch, i have never installed any before so any help is very appreciated
Discuss how do i get these little buggers in then? in the Talk Electrician area at ElectriciansForums.net
Need a little more info, what sort of plug is it!
Take no notice of me.
I thought you're an eletrician? or at least apprentice.
Widdler,
That's your one and only post used!!!
I have recently became an electrican, i have done re-wires on my own, changes consumer units and all the things that go with it, passed all of my exams so far with distinctions but i'm still learning and i have never done downlighters so instead of scratching my head about this for a whole day i thought i might ask you genius guys (if thats ok)
MC
Sorry if I offended you.
Like I said, take no notice, I'm stuck at home to tonight drinking beer, wife's elsewhere, I'm 'baby' sitting, so I'm bored.
A
It is Friday night after all...
Ok i will have a stab. Only do this if the plug is a normal household plug like the one on your hairdryer or iron, i assume you have one or the other and know what i am referring to.
1, cut off plug which supplies 230v to transformer.
2, Connect Brown wire to switched live on your lighting circuit.
3, Connect Blue wire to lighting circuit neutral
4, If it has one then connect earth wire to lighting circuit earth.
5, cut holes in ceiling,
6 shove lights into holes
7, do all tests etc
8, switch on, standback and admire.
9, dont blame me if the plug you describe is different from the one i assume it is and it all goes bang.
Cheers..........Howard
Reply to how do i get these little buggers in then? in the Talk Electrician area at ElectriciansForums.net
