How do I remove the front cover from a Vent Axia extractor fan plumbing advice | on ElectriciansForums
Guest viewing is limited
Discuss How do I remove the front cover from a Vent Axia extractor fan plumbing advice in the Plumbers Forums area at ElectriciansForums.net
How do I remove the front cover from a Vent Axia extractor fan The model number is not shown, but I have attached an image of the model. There are two small flexible plastic tabs underneath the fan. I have tried squeezing them together. They click but they don't release the front cover. I have tried pulling the lower edge away from the fan but am reluctant to try harder and cause damage.
How do I remove the front cover from a Vent Axia extractor fan to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to How do I remove the front cover from a Vent Axia extractor fan plumbing advice in the Plumbers Forums area at ElectriciansForums.net
M
How well does bunging the cold feed and Open vent work Have a radiator to swap. I'm thinking of piping back to the current supplies. The rad is...
Matt0029
M
Vent valve greenstar 35cdi compact how to get back inside Hi Took the vent valve off which has a spring clip and sits in the top right hand side...
diy_massacre
Recommended Sponsor News
Hi everyone,
