Lansberry123
Hello, i am having issues wiring my garage... i am running my lighting circuit. First, i wanted to run my power feed from the panel, to a junction box (which will split towards a motion activated flood light that is continuously powered, split to the garage door opener, and split to a switch to power separate work bench lights).. my first junction box split is as such... panel box, to junction box, to motion activated flood light (always powered), to light switch, to ceiling lights for garage. I wired hot to hot and neutral to neutral and ground to ground at the JB and the motion flood light, then i ran Down to the switch to where the circuit will be broken to turn off/on the ceiling lights when needed. I pig tailed the 2 neutrals at the switch and connected the hot wires into the switch, and also connected the grounds. I didn’t wire in any ceiling lights from the switch yet, but i turned my breaker back on and the flood light connection box keeps popping and sparking when the breaker is flipped on.... what do i have wrong here?
I don’t want to break the circuit until after the flood light, once the circuit hits the switch for the ceiling lights.
