How do I wire this light switch?? | on ElectriciansForums
Discuss How do I wire this light switch?? in the Lighting Forum area at ElectriciansForums.net
Ormskirk
This switch controls 2 outdoor lights. The lights each have 2 live, 2 neutral and 2 earth's plugged into them.
This switch didn't work and when I looked behind it was wired like this!
Anybody know how this should be wired??
Thank you!
[ElectriciansForums.net] How do I wire this light switch??
Possibly left like that because the switch and wiring was installed some time before the outside lights were fitted, and it's never been fully connected. Still needs investigating and testing, though.
Is there a third light?
If there’s 2 each of live neutral and earth, the last one should only have 1 of each.
Although the switch looks straight forward enough, dead testing would clarify what should go where.
Reply to How do I wire this light switch?? in the Lighting Forum area at ElectriciansForums.net
brilliant thanks for your support. Lee
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
