How do you clean polished louvres and opal diffusers? | on ElectriciansForums
Discuss How do you clean polished louvres and opal diffusers? in the Commercial Electrical Advice area at ElectriciansForums.net
M
MrW
Does anyone know how to clean polished louvres and opal/polycarbonate diffusers? I know some detergents can wreck polished louvres so you have to be careful.
I own a commercial kitchen and use this for everything:
Cif | Power Cream Kitchen
It's fine on the clear diffuser on a flourescent we have. I don't think the latest version of this cleaner damages anything, but it still works very well.
The new version is a clear liquid in a yellow bottle the old one was a yellow liquid in a clear bottle, this tended to damage gloss paint.
I think it more important what you use to wipe it with, as in, you wouldn't use a scouring pad to clean something polished. Wait Untill anything hot has cooled down before cleaning (aluminium sort he's very easily when warm for example).
Glass cleaner is also very good, I use Tesco's own brand (green liquid), it's the bst I've found. It's a very good light cleaner and may be perfect for you as it won't leave streaks.
You could try sugar soap, it's a bit alkaline but it should be fine, maybe just try a small test area first though. It's cheap and should be easily available from most hardware stores.
Reply to How do you clean polished louvres and opal diffusers? in the Commercial Electrical Advice area at ElectriciansForums.net
I removed a corrugated asbestos roof from my kitchen extension and took it to the council dump. It cost me £10 per sheet. Double wrapped in 120...
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
