How do you connect an Automatic Door to a fire alarm panel????? | on ElectriciansForums
Discuss How do you connect an Automatic Door to a fire alarm panel????? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Anyone know how to connect a bi parting automatic door to a fire alarm panel, i think i know where it connects into the panel but have no experience with these doors!!!
I need to open the door when the fire alarm panel is in fire mode!!!
The Board is a "Sabre"!!!
Any help on this would be grateful!!!
:confused:
I would say you need a fire alarm interface or input/output unit adjacent to the door, that is sitting on the fire alarm loop.
There will also be a relay somewhere in the door controller which will be specifically for fire alarm contacts. With this you can pretty much make it do what you want, although I dont know if you can have them to remain open in the event of fire, more than likely just to be free opening.....some further investigation is needed on your part.
Do you have a design spec for this job???
No, no design spec!!! But from wat you`ve told me i can figure the rest out!!!!
Lenny your a diamond!!!!!
Thanks mate!!!!
if its like a shop front sliding door iv seen some thst are "Kick away" ie the panel is held but in emergency they can be kicked out like norma lswing door
Reply to How do you connect an Automatic Door to a fire alarm panel????? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
D is the negative for the SAB hold off supply In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C...
These keypads are obsolete and replacements are hard to find, I've replaced loads now with failing displays. Sounds like something isn't...
