M
mrsonic`
greetings
is there a device out there that can identify which wire is which in 2 way circuits? for example, if your lamp outside is controlled by a 2 way switch upstairs and downstairs, and you want to know which wire upstairs and downstairs is L1.
Is a continuity tester suitable for this investigation? how about disconnecting mains, go to the switch upstairs, put alternative power in wire that goes in L1 (about 20-30 volts) and then go downstairs and check which wire has 20-30 v running through it, using volt meter?
