How do you rate this tester? | on ElectriciansForums
Discuss How do you rate this tester? in the Australia area at ElectriciansForums.net
In a word no it wont do all the required for 17th Edition. however if you can lay your hands on a Robin KTS1620 then this will. A finer piece of kit you will not find, I had one for several years and only stopped using it cos it got broken. Brilliant tool and very easy to use, ideal starter kit in my experience.
But the Robin serperates are just as good and easy.
Cheers.........Howard
only prblem with seperate testers is when it comes to having them calibrated it can get expensive. I know cef do a half price day but even then it might well add to more than ÂŁ100 to get 3 testers done. Just so the nice part p man can be kept happy
Reply to How do you rate this tester? in the Australia area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
The contacts are pushed open by a cam as the shaft is turned so they operate quite slowly. That's fine on AC as any arc is self-extinguishing at...
