- Joined
- May 7, 2009
- Messages
- 129
- Reaction score
- 1
''I had an interesting fault the other week whilst checking that Class 1 metal socket fronts were earthed. Admittedly it would have been best to carry out whilst dead, however this was just a quick check for peace of mind after doing a different job at night. I found 50v between the metallic light switch front and the main earth terminal at the consumer unit. When the light switch was switched on there was 100v. Further examination showed that the CPC (Earth) to the light switch was disconnected in the ceiling rose. Tests of the earth at the rose proved ok, IR tests on the switch cable proved ok. Reconnection of the CPC (earth) eliminated the problem. All I can put this down to is induction from the live conductors to the CPC conductor. One to look out for though''
originally posted by
topcop999
can anyone please explain why this happens?
Is it down to induction ?
thanks chris
topcop999
thanks chris
