How does a photocell work? | on ElectriciansForums
Discuss How does a photocell work? in the UK Electrical Forum area at ElectriciansForums.net
Tanzania
Can someone explain to me with a sketchy circuit as how a photocell we install in homes for fence lights actually works. Animation video or normal would be greatly helpful.
Do you mean what it actually does? In that situation it would act as a light switch which turns the lights on when the lux level reaches a certain low and keeps them on until the lux level rises again. These levels can usually be found in the in the manufacturers spec for each one, sometimes it’s adjustable.
For actual how they work, the most simple design connects a light dependant resistor in series with a low power heater element. The heater element is attached to the bi-metallic strip of a thermostat. When light shines on the LDR, current flows and the element heats causing the thermostat contact to open, switching off the light. As it gets darker, less current flows, the element cools and the thermostat closes, switching on the light. There can be quite a delay in switching on with this type, the switch off tie is a lot quicker. I was playing with one of these earlier this week..
Reply to How does a photocell work? in the UK Electrical Forum area at ElectriciansForums.net
It applies to commercial if it shares the same supply as a dwelling.
Hi I've nearly completed the 2357 NVQ. I'm just a bit stuck with Permits to work, Planned program of work and method statements. I work in the...
