Pali
I have a Boiler connected to a Megaflow and 6 Radiator Zones.
I would like each zone to be individually controlled via a Heatmiser Solution.
Keen to understand how each of the individual thermostats (Neo Stat) will tell each individual radiator valve to open and close deepening on the temperature required.
Heatmiser tech support advise that I can use motorised valves to achieve the same. But not sure how that will work
I think the only way is to have an 8 Port manifold & Actuator. The thermostat will tell the actuator to open and close the valve on the manifold which in turn will warm up individual zones as required.
Please help.
Please help.
