How far away would you make Next Inspection? | on ElectriciansForums
Discuss How far away would you make Next Inspection? in the DIY Electrical Advice area at ElectriciansForums.net
K
keith42
Hello everyone, just wondering what period you would allow to Next Inspection on the installation Certificate, in a case where you've fitted a new CU and recommended that a new earth rod is fitted + earth bond to an oil tank? Thanks.
Its down to you!
Only you know the "state" of the installation.
Could be anything between 1 year and 10 years.
Its down to you!
Well in the case where everything is okay, it's a new CU that's tested fine, but those items need doing.
When does an electrical installation condition report need to be carried out?
It is recommended that an electrical installation condition report is carried out at the following times:
for tenanted properties, every 5 years or at each change of occupancy, whichever is sooner. At least every 10 years for an owner-occupied home and at least every 5 years for a business
A new earth rod and oil tank bond.
Oh right sorry misread your thread, should you not have bonded the oil tank and fitted a new rod at the time of the CU change, it seems an important thing to just recommend.
Looks like you may have left yourself open to some criticism by not doing these jobs at the time you changed the CU as Murdoch mentioned
My guess is that you have either C1 or C2 (or both) coded this job. so you could give it the maximum recommended time as per the table in GN3, but consider your test results when making that decision. The EICR is worthless whatever you put on it, because it says, i/we recommend that this installation is re inspected in however many months or years subject to the items requiring remedial action are sorted out, or words to that effect. I can't be bothered to dig GN3 out, so have a look on the EICR form for exact wording.
Cheers............Howard
Ignore the last crap, i have just re read your post. The earthing arrangement and bonding should have been sorted BEFORE you put the new CU in.
Cheers...............Howard
I think this should agreed with the client to be included as part of the CU change, then situations like this would be avoided.
whats wrong with the current rod? and the earth bond to the oil tank should be mandated at the time of the CU change
The job was just to replace the old CU. The existing earth was to Neutral, it's there but high resistance. The oil tank/boiler went in in 2004/5.
So should it not have been certificated, strictly speaking? Or is it okay with an early Next Inspection?
I am the customer, btw.
By that do you mean it was/is a TN-C-S system? If the impedance is out of range it should be notified to the DNO as it is their responsibility to maintain any earthing facility they supplu
Any CU change involves testing the circuits fed from it and certifying the work carried out.
I find your last sentence very worrying.
Which country do you live in? what paperwork has the spark given you? and have you paid the spark?
Reply to How far away would you make Next Inspection? in the DIY Electrical Advice area at ElectriciansForums.net
No it is not implying it is safe, it is stating what the recommended date for the next inspection is. The next inspection date sticker doesn't...
davesparks
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
