Hi All,
Thought i would throw this one out there, just recently after an NIC visit the engineer picked up on something on an EICR we had carried out, the test was carried out on an underground station on a small metering circuit, all was fine apart from a bit of labelling, as this board was on a sub-main and the contraints of the underground where you are only authorised to work in certain areas and the db could of actually been fed from another station it was not possible to gain access to the origin to assess the eartning and bonding and incomer particulars, so we had put this down as a limitation to the test, just wanted to get a feel for what you guys would of done in this situation of limiting the assesment of basics of the system.
Chris
Chris
