How is the direction of this motor controlled Gauge door opened ( 240v AC) | on ElectriciansForums
Discuss How is the direction of this motor controlled Gauge door opened ( 240v AC) in the UK Electrical Forum area at ElectriciansForums.net
Uk
How is the direction this motor spins controles from what I can trace the white is directly attached to the neutral. ( Might be wrong on that, ) Thanks in advance, Simon
[ElectriciansForums.net] How is the direction of this motor controlled Gauge door opened ( 240v AC)
You are correct that the white wire should connect to Neutral.
Then the capacitor connects between red and blue (capacitor with twin tags on each terminal for convenience of wiring)
You apply power (eg Live) to the red capacitor tag to make it go one way, or apply it to the blue tag to go the other.
To implement that you could use a momentary (sprung) single pole two way (spdt) switch, with the Live feed connected to the switch centre/common terminal.
The motor is rated for intermittent use, so you wouldn't want to run it for many minutes continuously otherwise its thermal protection might kick in and the motor stop.
NB: Reference to Live and Neutral assumes you are using a 120V supply! (Motor states 120V 60Hz which is not UK mains)
Reply to How is the direction of this motor controlled Gauge door opened ( 240v AC) in the UK Electrical Forum area at ElectriciansForums.net
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
Do you have a test meter of any kind? if so, disconnect all four wires that go into the motor and check for a low resistance between them. You...
