There are no specific regs as to how long it is.
However it will have to meet regulations regarding volt drop calculations.
as long as the Zs at the spurred socket is below 1.09 ohms it's good (assuming a 32A type B MCB), and of course VD below 5%. (11.5V).
If if longer than a drum of 2.5 then its too far...:cool:
In all seriousness if we are talking domesticated dwellings then it’s unlikely to ever exceed maximum permissible lengthy
I want t run a spur(using 2.5mm cable) from a socket on a ring main . how long can the spur cable be?
Lots of imponderables to deal with Voltage at final destination ( have any volt drop calculations been done?)
[automerge]1570541797[/automerge]
not sure how to do v/drop calc , the spur will be approx 4m. i want to run a tumble dryer from the spurred socket
What is the Electrical load of the tumble dryer?
if you're going to run 4m 2.5 cable, why not run 2 cables and extend ring in existing socket using wagos or ideal in line splice connectors. it's less than a fiver for extra materials
[/QU
thought about extending ring but nearest point to break into it easily and fit conector block will be 6/7m . The 4m length would be fed from back of socket.
why can't you run 2 legs from the socket. joint in back box?like here?
You will need to be certain that the socket you intend spurring from is actually part of a RFC and not already a spur from the RFC, and your addition is NOT a spur from an existing Spur
the socket I am intending to spur from is part of the ring main. and is not a spur
[automerge]1570543634[/automerge]
thanks , will have another look at options
see picture in post #9. it's 1 I did last year. obviouslytrhe red/blacks are existing. the brown/blues are my rfc extension., clipped about 3m under floor in crawl space. ( this is what thin apprentices are for. :):):)).
because today he wants to run a tumble dryer; next week he may want a dishwasher and a washing machine in the same location. as it's only a 4m run, why skimp for the sake of a few quid?
nope
but at the moment he wants to run a tumble dryer, end of, perhaps he might want a sauna, who knows, but for a tumble dryer, its fine
nope
don't dispute that, but for the cost involved in extending the rfc, why limit the work to a single accessory point.
Its a tumble dryer, unless I've missed something it won't be 4.5Kw, even if it was, its still not 20 amps, why do you think spurs are legal Telectrix, you're over complicating it, no need to extend the ring
so you'd be happy pulling 4.5 kW off a double socket, rated at 20A?
There is no reason why not, two laundry appliances are often plugged into a double socket and neither appliance will pull full load constantly even when running together. 4.5kw equates to 19.6a @ 230v, in practice it's likely to be 18.75a @ 240v. I would not claim a spur would be the best way to do it, but neither is it wrong, especially as the OP has stated the intention is only to run one appliance.
mupost was in reply to fairlight's post re tumble dryer and washing machine both on a twin outlet. each will have a 2.2kW heater. add a bit for the restof the machines'bits.... 4.5kW.
i don't disputethatfor 1 appliance aspur complies, but that the cost and effort to extend ring is minimal.
[automerge]1570605483[/automerge]
this had a washer and tumble dryer connected.
It complies for two appliances plugged into a double socket on a spur. A preference for a ring is a perfectly legitimate point of view. But to suggest that a spur supplying a twin socket does not comply is plain wrong. And regardless of a ring or spur, the load on the socket will be the same.
I'm not arguing that it complies or not. just that for what's involved, extending the rfc would be my preference. with a spur, if OP were to want another outlet adding at some time, he'd have to retro fit a FCU.
The pic you have posted above of the burnt out socket shows both line pins overheated, this is probably due to a poor quality socket or plug top, and with those two appliances plugged into that twin socket it would make not a scrap of difference whether it was on a ring or a spur.
london
United Kingdom
how long can a spur cable be
oldandtired,
Zerax,
