C
craig1000
Hi am after a guide as to what people think is reasonable in time to take doing either a PIR or ECIR?
Im recently set up with my mate & i am the one doing our testing etc, i have experience doing so on site in a commercial environment new builds but we are getting in our own work on both domestic & commercial.
Just done a ECIR on a domestic, it was a right old mess n shamble after many years of alteration id say by a DIYer, new owner doesn't have a clue what does what.
Mains split & fed 2 single way units, 2 4 way units & a 6 way unit, 1 of the 1 way units then fed another unit in the loft!
With nothing marked up & many things in poor condition it took me all day 7.30 -17.00 to go through it all, & i had by business partner with me as we had nowt else on so in total 2 blokes 9 hours!
I accept this is along time but being new to the situation i am wondering what sort of time others would expect, in total we inspected & tested 19 circuits fully, going round disconnecting all appliances, removing lamps etc so could do all IR tests P-n, P-CPC & N-CPC! iv seen some posts saying that people don't do P-N?
Due to the condition of the install i was pretty thorough in looking at things n it took a while just to work out what did what due to nothing being identified at the various CU's, no indication of any previous testing & some various faults, especially the stuff serving the garden!
I want to know if im being to fussy, to slow or what? I know with more experience i will get faster in the domestic situation but as a guide now it would be good to hear thoughts?
I am assuming maybe a EICR will be a more in depth report than a PIR as with a PIR if there has been a previous one you should be able to with a little inspection (10% of install) get on with the testing & know what does what as from the previous PIR info!
Where as a EICR you need to check allot more than 10% as you have no evidence of it previously being up to standard & in my case no final circuit info so no idea what did what until we worked it out!
Should i be correcting C1 issues as i go or just reporting them?
Any replies have my thanks in advance!
