With a smart charger and 5 out of 6 batteries I want to keep in good order it is a case of clip and charger and remove again one or two weeks latter. Using an energy monitor on supply to charger it is clear as the battery charges it auto turns off, however I have one odd one out, a 95 Ah battery fitted to a Kia Sorento which will to start with follow the normal charge pattern, 3.8 amp, 3 amp, 0.8 amp the 0.1 amp. And it will at 0.1 every so often return to 0.8 amp charge rate, this is same for most of my batteries, the smaller ones will switch completely off then return to 0.1 amp.
However as time goes by with the kia battery the time between the two charge rates gets shorter and shorter, first time it switches to 0.1 amp it stays at 0.1 amp for nearly 12 hours, a day latter going to 0.8 amp charge rate twice an hour, the time at 0.8 amp is shorter, but last time ended up swapping between the two rates 8 times an hour, at which point I took it off charge.
The charger drops charge rate once it hits 14.4 volt, and lifts it back up again at 12.8 volt, so it ends up being pulsed, no other battery does this, so can't decide if to leave pulsing and see if settles, or to take off charge? Battery age unknown but over 4 years old.
