how many amps? | on ElectriciansForums
Discuss how many amps? in the Australia area at ElectriciansForums.net
G
gpz900jim
I know this is a really daft question, so please dont shout at me but I cant work it out. I have 5 x 50 watt 12 volt bulbs powered by a 230 volt to 12 volt transformer. Could someone kindly tell me how many amps they use??? :confused: Thanks
250 watts at 12 volt. P=IV therefore I=P/v. I = 250/12 = 23.8A. ssssssimple. must be a bllody big transformer!
your amps at 230v would be just over 1A
Basically ohms law V =I/R = 250 watt / 230 = 1.09 amps
i couln't be ***** getting up for the abacus to work that one out. just spotted that one nick. have you got a different ohms law in wales???????
You using your estimating calculator matey!!!!!!!
got up for the calculator once. enough is enough. have to admit, i'm old school. when i did my learning bit, the most advanced calculator was a slip stick ( those of us lucky enough had one with HP-KW bit on them. the only thing digital was a red led watch and they cost ÂŁ100. that was a months wages then.
Opps ...lol look ive spent the afternoon out side in the pooring rain up to my knees in mud jointing a 25mm armour some numpty cut through with a JCB , yes rocker it should have been power law , answer was right though lol so it should have read I= P/V
Most exciting thing I could do with a calculator is write ******** when u turned it upside down..lol
well, what would you expect from Hull. wasn't it somewhere there they hanged a monkey as a spy?
The answer is 20.8 Amps.
This is why ELV lighting needs either heavy duty cable, or alternatively, one transformer per lamp to minimise cable runs. Dont do what the numpty did at our house which was have 8m runs of 1.5mm from a single tranny and wonder why the lights looked if they were on a dimmer.
We installed 11 50w downlighters and each had its own transformer.
Does the lamps no good either if you know about tungsten filament bulbs not working at their rated power.
Reply to how many amps? in the Australia area at ElectriciansForums.net
By code the washing machine needs its own 20 amp single pole GFCI circuit, the dryer needs a 30 amp double pole breaker and using # 10 wire. Your...
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
