how many certificates ?? | on ElectriciansForums
Discuss how many certificates ?? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
shocked
Hi all
If i wire a new circuit say a cooker point and the customer asks me to test the house wiring do i have to fill in a ELEC INST CERT and a PIR or can i just fill out the E I C with all the results on the SCHEDULE OF TEST RESULTS.
Trying to save paper ???
Thanks for any replies
john
Hi all
john
You require both, I would do the PIR first, then depending on the outcome the EIC, you may have to increase the size of main earth, RCD etc to ensure compliance with BS7671:2008.
When issuing the EIC ensure in the discription that it only for the new circuit.
Reply to how many certificates ?? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
Yes I think back in the dark old days they were called deeds but are now called contracts and some still refer to it as deeds like I did! Sounds...
