how many certs | on ElectriciansForums
Discuss how many certs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
E
esc
Hi guys, i'm to replace a couple of cupboard luminaires, an extractor fan and a few SO fronts. They're all on the same circuit, RFC, the luminares and extractor are each on a 3A FCU. Being off the same circuit, can i put all these separate jobs/items on the one MWC?
Cheers
i would guess you can, but personally i would be doing seperate ones. If you are replacing like for like accessories, you dont have to do any certs - although better to, just to confirm / prove you have done the required checks
One MW for each circuit.......so if all your work is on the same circuit just list the extent of work and record the highest measured test results.
My preference is to keep paperwork to the minimum to meet the requirements....the world is overun with paper....as above if it's like for like you may consider a cert unecessary anyway.
Reply to how many certs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks for the advice.
I wonder if a double row Fusebox would fit in there…
