J
jmc1683
I am currently re wiring an 11th floor apartment in central London. the apartment was last wired in the 80's. on problem is there is only one coax aerial coming from main riser outside apartment to main t.v location, nowadays I always run at least 2 or more to every t.v point especially the main, as is required by modern sky and cable. in this case it is virtually impossible to run a second cable, would require MASSIVE work, how necessary is it or is there an alternative, some piece of technology im am unfamiliar with? just looking for suggestions, thanks....John
