I have Collingwood hs2 extreme led dimmable lights I will be installing in the soffit around the house.
The lights specs are:
Input current 0.02A, input power 4.6w, inrush current of 1A, 0.24ms, power factor of 0.8.
Collingwood suggest that 7 units can be connected to 250w dimmer, 14 to 500w and 21 to 1000w.
I want to use fibaro dimmer2, which is rated 50-240w for conventional.load, and 50-200va for capacitive.
Would be ok to connect 7 units to it?
